150TXRB will not fill oil tank.
  • 150TXRB will not fill oil tank.
    Engine mounted oil tank will not fill. Either Auto or with the switch on the back of the motor.
    Alarm sounds and engine cuts out when oil level is low so we know the float switch is good.
    We replaced the remote tank pump and when jumpered directly to the battery it pumps like crazy and will overflow the tank, so we know that pump is good and the lines are good.
    What's left? Is there a schematic and TS guide for this issue?
    S/N 5G4X1004795
    JOhn ><>
    [URL="http://www.Stuff4Toys.com/"]Stuff4Toys.com[/URL]
    If emergency override toggle switch on engine doesn't operate oil transfer pump with ignition in on position then probably a bad wire harness between engine and remote oil tank.
