2006 F75. I have always use a transom support. Problem: the trim/tilt system has a bit of slack. When the motor is trimmed up for road travel, if you pull up on the leg you can lift the motor up a bit. Watching the chrome ram you see it pull out of the cylinder just a bit, maybe a 1/4". There is NO sigh of a leak. The manual release screw was able to be tightened a 1/2 turn and the nut(fill/check cap??) was able to be tightened a very small amount. Is the slack normal should the motor be rock solid (no play) Do I have a problem? if so what is the fix. Can anyone help me with the correct way to check the fluid level.Thanks to all.
F75 tilt/trim help needed
