I am frustrated. I changed the impeller on my 07 F150. Everything looked good. Everything went together just fine. I also changed the gear lube. Used yamaha lube with yamaha hand pump. Filled it straght up and down until lube came out of the vent hole. Cranked it up, telltale flowed like it should, all was good. Took it to the lake to run it, and there was a rattle when I put it in gear. It shift into and out of gear just fine. Low RPMs it sounds like the top of splines are rubbing or there is a clicking noise coming from the foot area. Noise coincides with the RPMs. Noise goes away after 700 rpm or so and all is good again. I pulled it apart and tried to reseat everything, but nothing seems to help.
Anyone have any ideas?
Kyle
Kyle
