F115 Oil Pressure Alarm
  • F115 Oil Pressure Alarm
    Hello!
    I have a Yamaha F115 that ran great last summer. I'm in the process of completing annual maintenance. I ran the motor for about 15 minutes yesterday and I'm having trouble with a oil pressure alarm showing up on the instrument panel. I havent changed the oil or filter yet...The oil level looks OK at the "a" level, the color of the oil looks good, but I did detect a slight fuel odor. Can you help me understand what can cause the oil pressure problem and steps that I should follow to resolve the problem?
    Problem Fixed
    Well how about that! I fixed it....the oil alarm light stopped blinking after I changed the oil and the oil filter....Motor runs great.. I'm still not sure why the oil smelled liked it had a little fuel and the oil level was higher before the oil change than after. I filled with 5 quarters and the oil level after operating the motor was between "a" and "b" lines. Before the oil change the level was right on the "a" (high) level line.
