I have a 2003 90 hp that is leaking oil out from where the driveshaft goes into the powerhead, I removed the cowling apron and can see where the shaft goes into the powerhead, when running it leaks a steady drip. Is there a o-ring, or crank seal that is in that area?
I replaced the water pump just before it started leaking, could I have damaged the seal?
Thanks in advance!
Thanks in advance!
