93" 70tlrr...
  • 93" 70tlrr...
    1st.
    trying to convert my 70TLRR to a tiller handle (pt# 6H3-W0086-Z0-4D ) turns out its a disscontinued part! but i see pics of another handle ( pt#65W-W0086-Z1-4D ) the numbers are very close and from what i see in the pics it looks like it would work......will it, and if not ......why not.
    2nd
    i suspect the oil injection pumps not working so i decided to remove it and just mixs the gas, when i took the pump off i see a hole in the block. can i just plug the hole somehow and carry on .......its a precision blend motor so does that mean the motor wont work without the oil pump.....
    motor is a 70TLRR ....1993 i think......S\N 6H3 481791
    im a big fan of using tiller and would love to keep doing so...
    Not sure of that tiller handle will work probably not, never tried it. You will have to plug all holes in block and intake when you remove oil injection.
