Llamaha
  • Llamaha
    I have an F25TLRZ (twin-4 stroke) and one cylinder cuts out intermittently at all rpm ranges. I'm assuming that it is a bad coil, but there may be other causes. New plugs of course. Any suggestions? Thanks.
    That coil fires both cylinders at same time but if it is not firing on one cylinder then it's usually plugs or plug caps. It could be the CDI or possible coil.
