1990 Outboard I need help! (and a part)
  • 1990 Outboard I need help! (and a part)
    Hi,
    My husband just called me from Lake Nipissing in Ontario, and he had my 1990 20 HP Yamaha short shaft, 2 stroke engine (bought in Canada) overhauled, (cause he hit a rock...)
    anyway....the serial # is 001433
    Model 20MSHP
    The part that is broken is the little red button where you attach and remove the black plastic key.
    My husband says he now has to put 2 wires together to start the motor.
    He says it's the on/off switch that is broken?
    I'm sorry if this is not very helpful, but can you help me from the little info I've given you?
    He can get the part up there, ($170) but I am in Ohio and it would be cheaper if I can buy it down here.
    He will eventually get the part number from the guys who did the overhaul, but I thought perhaps I could get moving on this without it.
    Thank you so much.
    Diane
    The 20hp model was only available in USA in 1996 and 97 but stop switch should be same, it's number 27 in this diagram Yamaha Outboard Parts 1996 20MLHU BOTTOM COWLING Diagram
