on my 1989 pro V 150, it won't shift into reverse sometimes and have no more room for adjustment on my shift bracket in reverse........do I have to drop the lower unit to move a tooth on the spline and then adjust the cable or is there another way to make adjustments???
Edit: I just replaced the prop shaft before original posting and have about .040 end play measure between the prop and the housing. There are 5 shims behind the bearing carrier.....would removing a couple of them help ???
