no spark on number 2 middle cylinder engine not starting .have change coils about still no spark,any ideas ,engine will run in safe mode on cylinders 1 & 3 I have just about had it with this engine everyone says they are bullit proof any one got a gun and we will find out
90hp 2 stroke 6H1 90AETO ignition
What did your testing of the charge coil outputs and pulsar coil out puts show? What year is this motor? Does it have 2 Pulsar coils or just 1?
Here is something that talks about how a early 90 fires http://forums.iboats.com/showthread....96#post2656596
Are you saying that #2 will fire when you disconnect the crank sensor?Last edited by 99yam40; 05-17-2010, 09:39 AM.
90aeto
hi cuan ferry, I have seen this and other problems like this disscussed on you tube , so that might be a reference for you. The second thing is your motor 90 AETO , I have a motor just like that , and was wondering how to determine the year of the motor. I hope in the middle of your problems ,you can help me with mine. thanks
90hp 2 stroke 6h1 90AETO
Ok Story So Far. No Spark No/2 Cylinder. Ht Coils Tested By Rotation And Apeer Fine. I Have Replaced Cdi Unit Still Have Same Problem No Spark No/2 When I Disconnect Crank Shaft Sensor I Can Start Engine But I Will Not Start When Sensor Is Pluged In.when Sensor Is Pluged In It Fires Then Shuts Down As If Key Is Being Turned Off. Have Not Checked Stator Or Pulsar Coil Yet But Given The Engine Starts I Think Could Rule Them Out Q.would Regulator Have A Bearing ..? Engine Is Early 90s And The Cdi Has Advance Retard Fitted In It
You should be getting 5 peak reading volts between white/red and white/black pulsor coil wires at cranking speed and 5.5 peak reading volts between blue/red and blue/white crank position sensor wires at cranking speed.
