99 250 no spark
  • 99 250 no spark
    have a 99 250 saltwater ox last winter motor was submerged got it out got it flushed started and running changed some of the wiring on it know just noticed that when looking at it from the front the right side is not getting any spark on all three cyl could it be the stator under the fly wheel or is ther any advice as to where to start cant afford 90hr just before it sunk i just paid over 1800 to have it serviced it starts up and runs but when i checked the plugs noticed the right side was wet from fuel and checked for spark and found none any help would be awsome
    Check for corrosion in wire connections and ground wire connects, check shift switch and all sensor leads.
      thanks
      well thanks did what you said and know have spark on all just sprayed with electrical spay and comprressed air on every wire connection once agian thanks
