trim switch
  • trim switch
    This afternoon the up & down trim switch on the Yamaha binnacle stopped working in the up position [it works on the motor] so I would think the switch needs replacing. The motor is a 2000 200hp OX66. I can't find my year & would like to know if the switch is standard thru 2005.
    thank for the help
    Check to see if switch on engine works, if niether switch works then could be a faulty trim relay.
    Here is link to parts list on control box which should be same as your control box Yamaha Outboard Parts 2005 OUTBOARD RIGGING PARTS BREAKDOWN
      Thanks for the reply, but as stated the switch on the motor works up & down
