1987 115 stalling under load
  • 1987 115 stalling under load
    I have a 1987 Yamaha 115hp. Picked it up last sept. its on a 73 19ft Boston Whaler Outrage, very low hours, boat was always trailered. It ran flawlessly from oct till dec, I winterized it ran stabil through the carbs the who nine yards. Was using a portable tank last season cause the tank in the hull was bad. Over the winter I replaced the Fuel tank all fuel lines, fuel water separator the engine filter everything is new. The engine starts right up, idles fine, revs up at idle fine, once in gear is goes at very low rpm, as soon as I put it under load it dies. I ran it off a portable 6 gallon and it has the same symptoms, any ideas? Thanks so much...Rich
    19 Steiger Craft F115 Yamaha
    Probably need to remove and clean carbs, fuel pump and engine fuel filter.
