Milky motor oil- '04 Yamaha 115TLRC
  • Milky motor oil- '04 Yamaha 115TLRC
    I have discovered water in my oil.
    What clues should I look for to find cause?
    This is a sudden event.
    Recent maintenance: Gear oil change, impeller change, motor oil and filter change.
    Run a compression test on engine(blown head gasket), look for oil leaks around drive shaft on bottom of engine(oil pump seal leaking)
