location of water pressure bolt to remove and install the insert
  • location of water pressure bolt to remove and install the insert
    Hello,
    I have a 1998 C 60 Yamaha 2 stroke and I purchased a water pressure guage for my motor. I also, purchased the insert to replace the bolt in the upper water jacket. I don't now which bolt to remove and replace the insert with. Can any one help me by putting up a diagram.
    Top of motor looking at from the rear
    1 Big bolt-----O
    2 bolt---o o----bolts A
    3 bolt---o SP o----bolts B
    4 bolt---o o---bolts C
    5 bolt---o SP o----bolts D
    6 bolt---o o---bolts E
    7 bolt---o SP o----bolts F
    8 bolt ---o o---bolts G
    I think it is the #1 Big bolt location pictured but I'm not sure
    Thanks,
    Mudd Minnow
    Here is the plug to use, the 60 and 70hp engines use a low pressure cooling system and may not show much or any pressure on gauge.
      Thanks, I thought it was that one but I wasn't sure. Have a great day.
      Mudd Minnow
