does a 03 200 hpdi have a poppet valve,when should it be change,what is the part #
200 hpdi
If you are referring to pressure control valve on cooling system then it's number 33 in this diagram Yamaha Outboard Parts 2003 Z200TXRB CYLINDER CRANKCASE 2 Diagram
Clean it at same time you replace water pump or if have a loss in water pressure.
