20 hp cm tell tale
  • 20 hp cm tell tale
    hi im a bit new to this the tell tale only starts to spray after about 1minute , is their a thermo stat, on the two strke engine. or does the impellor need changing. has any one got a supplier or ebay number
    Probably do need to replace water pump and check thermostat.
