If you are talking wiring inside control box then it only has red,blue and green wire going to trim switch and 2 brown wires going to neutral switch. Here is standard rigging wiring. 6YRW0035F2Wiring.JPG
Thanks-
I have a good 703 diagram that shows "Main switch", "buzzer", "neutral", "choke" etc. I guess you might say I'm looking for the internal schematic as to how each wire is routed. Looking for something like the attached file.
I'm looking for similar help. I have a 2001 T9.9 tiller model that I have to convert to remote. I have the elec. harness (6G8-82590-00-00), but I'm not sure where to connect to. If I unplug some existing connections to plug in the harness wires, what happens to the old wires?
Can't seem to figure it out.
Thanks, Marc
