wiring schematic for VZ300TLR 2006 year
  • wiring schematic for VZ300TLR 2006 year
    I am converting from a mercury to a 2006 yamaha 300hpdi. I have the engine running and I need a schematic so that I can be sure and get all the swiches and guages wired up.
    Matt Mc
    inevitablez@yahoo.com
    Not sure which gauges you are using but here is diagram for Yamaha digital.
      I am using the factory Gambler guages that is in the boat.
        Gambler probably uses purple, black and grey wire colors for gauges if so then on Yamaha key switch there will be a short wire with yellow, green, black wires.
        Connect Yamaha yellow to Gambler purple wire(key on power)
        Connect Yamaha green to Gambler grey wire(tach signal)
        Black to black
          You are correct I plan on being home this weekend to hook the rest of the wiring up. Thanks
          where can I obtain a wiring diagram.
