The battery voltage rises to just over 16V when I am running. I thought it had to be the voltage regulator/rectifier so I replaced it but get the same result.
Also, my multigauge for fuel level, oil warning, etc. flashes from time to time and resets. I am wondering if I might have a grounding problem. I have tried to check all that out but have not found anything strange.
Are there special grounds I should be checking? Any other ideas?
