I have a 06 4strk jet drive(F40EJR) and I only hit 5200 RPM's at WOT, shouldn't I be able to get a little more rpm's? Any thoughts or advice?
06 4strk RPM's?
That is within rpm range but it's on low side of range, about the only thing you can do is to adjust motor height up a little on transom.
Prop engines you can change prop to raise rpm's but jet drive there are not any other inpeller of different pitch available so there's not much you can do. You might have the engine checked out to make it is running like it should.
