I will be installing a new F60 on a Mexican panga soon.
This panga is a 22' side console open skiff that weights under a 1000#
I will need everything from a side mount remote control to steering and beyond, to be ready to launch.
Items needed are (I think)
Remote side control PTT w/electric harness (703 premium I believe)
Shift cables
Steering (rotary or rack/pinion) to include cables and a "destroyer" type wheel.
Steering link rod.
A digital or analog tach with hour meter.
3 blade aluminum prop.
Could you please list the parts and numbers that I will need, or have missed, that will get this setup ready to get wet.
I want to stay with genuine Yamaha parts, so as to not have any warranty problems if possible.
In addition, since I have no local dealer to purchase parts from, I would like to purchase normal replacement parts ie: fuel filter, oil filter and a water pump impeller.
On edit: On searching parts for a F60, it lists parts for TJR and TLR models in the 60 HP range.
Could you please explain the difference in these models.
The model I am considering is a 60 HP 4 stroke remote steering 20" shaft (current model year)
I am unsure about "high thrust" models....can you explain the difference please?
On further reading, I have found the model number difference. What I need is info for the F60 TLR model as the TJR is the jet.
Sorry more followup. Does the side mount control unit 703482071710 come with the cables included.
Shift cables
Steering link rod.
