I wanna put a tach on a 1993 c85tllr motor that has never had one on the boat what are all the parts i need ? My controls have several various colored plugins to connect to whicch one is which? thanks
Tach parts
Will need 6Y5-83553-N0-00 Gauge power harness that connects to green, yellow and black wires on 703 control box or to ignition switch.
6Y5-83540-14-00 Tach(set switch on tach for 12 pole alternator)
what is the diffrence in the 2 fuse gauge harness and the 1 fuse harness that shows up on the parts list for the motor?
Also what do the other wires go to on the 703 cotrol i believe there are lt purple and lt green together and red wire with the green black yellow wire
You can use the single fuse harness if its still available.
You will only use the green,yellow and black wires at 703 control, others are not needed to operate a tach.
ÂÂÂÂÂÂÂÂ
