THE LOWER SHIFT SHAFT ROD ABOVE THE LOWER UNIT ON MY MOTOR HAS HEAVY SALT WATER CORROSION....THE FAT DIAMETER YOU CAN SEE IS DOWN TO ABOUT 1/8 INCH IN DIAMETER AND I SUSPECT IT WILL SOON BREAK ... DOES ANYONE HAVE A BLOW-UP SCHEMATIC OF THE ASS'Y WITH THE PART NOS. AND ANY INFO ON HOW TO REPAIR IT . A LOCAL DEALER SAYS THE PARTS ARE PROBABLY FROZEN AND CAN'T BE TAKEN APART AND THE MOTOR IS LIKELY TOAST ....THANKS FOR ANY ASSISTANCE .
VINCENT.GEORGE@COMCAST.NET
