I have a Yahama 2003 150TXRB. When the ignition key is turned to accessory (straight up) the temp alarm goes off even without cranking the cold engine and stays on all the time. Even cranking the engine doesn't stop it. I have changed out the ignition switch with no affect. I have disconnected the heat sensors on the engine block and the alarm continues to sound. I unplugged the plastic wiring connector on the wiring harness beside the engine and the alarm will stop.
Buzzer Alarm
It's probably the low oil warning, check oil level in engine oil tank, if gets below bottom line on oil tank alarm will sound and shouldn't run engine.
Mnt
If your system has an engine tank with level sensing the float could be stuck at the lower (out of oil) position. I have a 1987 V6 and I had to clean the brass post in the sensor to get mine to work properly. There's a plastic "float" with a magnetic disk at the top that must slide freely on the brass post to make the switch work properly.
