have 1990 40hp yamaha model40eltd the prop turns at slow speed but does not at higher rpms found fishing line wrapped around output shaft when we pulled boat in fall is this a spun prop? and how do you fix problem? thanks in indiana
prop problem?
Yamaha 40 ETLD
Originally posted by patl View Posthave 1990 40hp yamaha model40eltd the prop turns at slow speed but does not at higher rpms found fishing line wrapped around output shaft when we pulled boat in fall is this a spun prop? and how do you fix problem? thanks in indiana
Thanks,
Irakli
ÂÂÂÂÂÂ
