Need some help on how to fill my trim on my 93 Yamaha S200TXRR 200hp outboard
  • Need some help on how to fill my trim on my 93 Yamaha S200TXRR 200hp outboard
    Hello all, I am a basically learning my boat mechanics as I have owned my boat for approximately 2years now. Need some help/direction please, on the following.
    #1. How to fill my Trim oil, due to observing a tiny leak around the motor tilt cylinder and squeeky noise as it tilts up/down.
    #2. How to open/take apart the trin cylinder to change the the seal possibly leaking.
    Any help will be gladly appreciated.
    Sonny.
    Raise motor to full trim up position, remove fill plug and fill with oil until level full.
    You will need a spanner wrench(call boats.net at 877-408-1499 for special tools) to remove seal caps to replace seals.
      thank you much, i take it that the seal is not pressurized so i can change it myself.
      Thanks again for the assistance
