Yamaha info to my Northstar M84 display
  • Yamaha info to my Northstar M84 display
    Hey everybody, I was wondering if anyone could give me some advice. I have 2006 twin yamaha's with square command link gauges and getting ready to install a new multi-function display. Is there a pig tail I can use to transmit my data to the M84? And if it's hardwired were do the wires go. Thanks for reading my problem and thanks a lot if you can help.
    Tight lines
    Bob
    If you want the Northstar to display engine data you will need a NMEA 2000 gateway to link Command Link to the NMEA 2000 network. Here is information on Gateway along with part number.
    O2009_014.pdf
    If you just want the Command Link to display GPS speed instead of pressure sensor on engine then connect the Blue(-) and white(+) wires from speedometer to NMEA 0183 output of GPS
      Thank you
      On that gateway will it matter if the M84 is 0183. It doesn't use NMEA 2000. I was told that my engines talk in 0183. So are the command link talk in 2000. I know I should be up to speed on this but as you can see I'm not. I'd send ya the M84 manual but it's too big.
      V/r
      gunz
        If the Northstar is not NMEA 2000 then you wont be able display engine data on it not even with Gateway. Command Link does use NMEA 2000 for engine data.
          oh well
          Well I guess that puts an end to that boat improvement. Thanks for the advice. Is there another product that people use to convert from 2000 to 0183?
          Bob
