225-changed oil tank float
  • 225-changed oil tank float
    the toggle switch will manually fill tank but will not pump from the onboard tank automaticly
    Do you have gauges with oil level lights? what lights are on? What year motor do you have? Could be either one of tank oil level sensors bad, one in boat tank or one in engine oil tank.
      yes no lights on got oil level gauge assy from your store for small tank on engine installed it and took the one out of the boats 2 gal tank tested it with meter when you turn it over it would open then close when i flipped it back but the toggle switch pumps it is a 1997 s225txrv if able could you email or fax wiring diagram email-lacombeselectric @ yahoo.com fax(318)-253-7431 thank you very much phillip
        I am encountering same type problem, 1992 Yamaha 200 HP, gauges are 2004, emergency switch pumps but auto does not. Is there a wiring schematic or diagram of the system somewhere? Second engine works fine.
          Check the oil level sensor in boat tank and wiring going to sensor, remove sensor and ohm test by moving float up and down and check for bad wires or connections between engine and oil tank sensor. Check engine oil tank sensor(it has three switches inside it).
            Going to be back at boat beginning of Feb and will check then. Thanks for the reply info.
