the toggle switch will manually fill tank but will not pump from the onboard tank automaticly
225-changed oil tank float
Do you have gauges with oil level lights? what lights are on? What year motor do you have? Could be either one of tank oil level sensors bad, one in boat tank or one in engine oil tank.
Originally posted by boats.net View PostDo you have gauges with oil level lights? what lights are on? What year motor do you have? Could be either one of tank oil level sensors bad, one in boat tank or one in engine oil tank.
Check the oil level sensor in boat tank and wiring going to sensor, remove sensor and ohm test by moving float up and down and check for bad wires or connections between engine and oil tank sensor. Check engine oil tank sensor(it has three switches inside it).
