yamaha fuel gauge
  • yamaha fuel gauge
    I want to hook up my lowrance fuel level sensor to my existing yamaha digital gauges what wires do i pick up?
    If you have the Yamaha Multifunction speedo then use the white wire on speedo to connect to fuel tank sender.
      the other whire goes to ground?
        If you have an older Yamaha speedo then connect the white/blue wire to fuel tank sender wire and don't connect white wire on speedo to anything(it's not used).
          i have the digital gauges
