F225 No Electric Power
  • F225 No Electric Power
    I am trying to troubleshoot an electrical glitch in the starboard engine. All batteries (2 starter and 2 house) are fully charged. The power tilt (from helm or on-engine switch) and electric start do not work. The starboard tach command link gauge powers up but does not show any data from the engine or battery (total hours, voltage, etc., all display - - - ) . It seems like there is no electricity getting to the engine. I have also tried to start/tilt the engine using the emergency switch (connects all the batteries in parallel) held down. The port engine is fine. Anyone have any ideas on how to troubleshoot?
    Check the fuses on engine. Check battery cable connections at battery and on engine are correct, clean and tight. Check main relay is ok, number 33 in this diagram Yamaha Outboard Parts 2006 and Later 4-stroke F225TXR 69J-1021983 ELECTRICAL 2 Diagram
