Hi, I bought a used outboard (longshaft) and replaced the water pump impeller. The old one looked pretty bad. When I started it up (at idle) water was steady out of the exit nipple but quickly slowed to a fast drip. With rpm the flow increased but still seemed weak. I pulled the lower unit off to check the flow tube connection. All looked good--metal tube with rubber sleave fit nicely into top of pump. Any suggestions? Shouldn't it be a nice steady flow?
Thanks for any help
Thanks for any help
