I have twin 1985, 150 etxk's, which came with two precision blend system [PBS] guages. These are 3" in diameter with 3, lamps, Green - oil level normal, Yellow - low oil, and Red -oil critically low. I would like to replace these guages, or circumvent them with a tach containing the appropriate lamps. Are either of these proposals possible? I can not find any part numbers. Can any body help?
Precision Blend System [PBS] guage
Those gauges (6E5-84301-01-00) are discontinued. You could get the newer tach to work as far as rpm's and oil level but trim gauge in new tach wont work with your motor.
New tach would be 6Y5-8350T-82-00 with rpm's, oil level indicators and trim indicator.
68F-82553-70-00 trim/oil harness
6Y5-83553-N0-00 power harness
[FONT='Times New Roman','serif']6R3-ADPKT-93-94 adapter harness[/FONT]
