Adding PTT Pump Fluid
  • Adding PTT Pump Fluid
    Is there a special tool used to fill the fluid into the PTT reservoir? When I removed the cap there is just a small fill hole.
    I have used a small diameter piece of flexible tubing attached to a plastic squeeze bottle that worked real well.
    Have you pulled the T&T motor yet and found out what kind of shape it was in?
      Look like water intrusion killed it. But now two of the bolts sheared off on the gear pump assy when removing motor. Looks like I just went from bad to worse!
      Thanks for the tip on filling reservoir.
