I have seen different weights for my motor. Does anyone know the weight of a Salt Water Series S150 TXRX 1999 two stroke w/25" shaft?
1999 S150 Weight
Here are the weights without prop on 1999 S150
S150TLR = 186kg (410lbs);
S150TXR = 190kg (418lbs);
L150TXR = 190kg (418lbs)
Thanks, the confusing part is I have a Genuine Yamaha Service Manual
(LIT-18616-02-01). When I try to find my model S 150 TXRX the models in the book are:
Model Name 150 FETO
US & Can S 150 TR
Indication S 150 FETO
These are the only ones that seem to indicate a Salt Water Series 150. Is this the model (S150TR) indication I should be following in this manual even though my motor is a S150TXRX?
