When running at half throttle, my 40LG will start to miss occasionally on one cylinder. If throttled farther, it will drop the cylinder completely. I have cleaned the carbs, changed spark plugs twice. I disconnected the oil level and heat sensors to see if it was a problem with that system. On inspection of the ignition, I found that the lower cylinder has weak fire, I swapped coils from another cylinder with no change. How do I check the CDI unit to see if it is the defective?
One mystery to me, the motor misses when running the boat, but with it on the trailer, backed into the water, it will run on all cylinders. I have checked the compression, it reads 120 PSI +/- 2 on all three cylinders.
This is a tiller steered, manual start motor, but I have added electric start.
Thanks in advance for any help, Jeff
