HI, I HAVE A 150 ETXH 2 STROKE AND MY SPARK PLUG THREADS CAME OUT OF HEADS DUE TO CORROSION, ANY SUGGESTIONS, IT IS A OLDER MOTOR AND I CAN REPLACE HEAD WITH USED OR NEW, BUT NOT SURE IF WORTH IT DUE TO AGE BUT MOTOR OTHERWISE RUNS AND WORKS FINE, THANKS MATT ANNAPOLIS MARYLAND........
Stripped Out Spark Plug Threads 150 Etxh
Probably be a matter of how corroded is rest of engine, pull head and see what inside water jackets looks like. If engine is ok then replace head.
I had the threads come out on a 115 Evinrude once. The Yamaha tech drilled the hole out and re inserted a thread bushing. Had to let it set from the adhesive for like 6 hrs, run the engine at low rpm until the the engine was hot. Let it set until cool and then run it normal until hot, re torque the spark plug. Worked like a champ.
Spark Plug Threads Stripped
i have come to the conclusion i need new or used cylinder heads, does anyone have any thing good or bad to say about putting on a set of used cylinder heads , my factory manual shows a diagram of decking/polishing them in a figure "8" patter, sorta a in shop milling? thanks,,,,,
Originally posted by JUST-IN-TIMEuse a time-sert, trust me, i do this for a living
and help cheap customers out,
This must have bee what our mechanic used and not a bushing. Bushing was the best way I could describe it. Any yes, it works great for low dollars.
