I have a 2004 VMAX 150hp Yamaha on a Ranger 188 bass boat.
Relationship between speed and rpm is off between 3,500 rpm - 5,500 rpm. Full throttle top speed is usually 55mph-57mph at 5,500 rpm. All of the sudden one day tach was showing 5,500 rpm at 3/4 throttle and 46mph. Engine will continue to rev and speed will continue to increase if more throttle is applied but I am afraid to go over 6,000 rpm. I have since tested another day on the lake and had the same problem.
Speed is GPS speed, trim works fine and is adjusted optimally for given speed, prop is fine. I have checked the prop hub and it is not spinning. Holeshot seems okay. Haven't hit anything recently.
Any ideas? Could something in the lower unit being causing these symptoms? Failing tach? Does the engine have a rev limiter that would stop it from over revving if I applied full throttle?
