I was wondering if anyone has used a ultrasonic cleaner like a sharpertek and the carb cleanning solution and if it worked good. I was thinking about buying one for my boats. Also I was wondering if anyone knew how to turn the rpms up on a 90TLR 2006 my RPMs are at 4000 at full throttle. I can be as high as 5500. Thanks
ultrasonic cleaner
Haven't seen that brand but the ultrasonic cleaners do an excellent job of cleaning carbs.
You can change a prop about 3 pitch sizes below the one you have and increase rpm's.
"Also I was wondering if anyone knew how to turn the rpms up on a 90TLR 2006 my RPMs are at 4000 at full throttle. I can be as high as 5500. Thanks"
What prop are u running? I would agree that 4000 is a bit low. RPM and prop dimensions are directly related. The factory prop should be a 13 1/4 X 17. (DIA / PITCH). Larger dia. and/or higher pitch = lower RPM's.
ÂÂÂÂ
