I have a 2000 model 50hp fourstroke on a 17 aluminum fishing boat and my max rpm is 5000, that's with one person and a half tank of gas, I running a 12x14 pitch prop. Is this rpm within specs or do I need to be turning more rpm's? Also when in neutral my rpm is 1200 and sometimes 1400 isn't this a little high? It seems to me that it hits hard when putting it in gear, where is the adjustment for the idle? Thanks
50 HP Fourstroke
The operating rpm range is 5000-6000 rpm's.
Idle rpm's in neutral for F50 is 750 rpm's, T50 is 950 rpm's(idle adjustment is on throttle linkage at carb)
You probably need to drop to a 10 pitch prop.
ÂÂÂÂÂÂÂÂÂ
