Can you help me identify the Yamaha multi-function tach?
  • Can you help me identify the Yamaha multi-function tach?
    I purchased a used tach hoping to use it on my 97 Yammy 115 but the connectors differ.
    Primarily:
    the two wire green/white and green/red connector uses round rather than flat pins;
    the four wire square connector for the Pink, Black/white, Orange, and Gray does not have the gray wire directly to the tach as does my original but rather terminates it with a bullet connector;
    and the tach has no DIP switches but rather the old rotary switch to select alternator/generator pole types.
    I need to know if I can make it talk to my motor.
    Pics attached.
    Steve
    That is a 1993 or older gauge, you would need adapter 6E5-82541-00-00 and 6E5-82541-10-00 to connect to 1994-2004 harness.
