winterizing 1991 225hp txrp
  • winterizing 1991 225hp txrp
    I have done most of the must do requirements for winterizing my engine:
    .add stabilizers
    .fog carbs
    .fog on each cilinder and change/replace spark plugs
    .take propeller out, clean and grease it
    .grease points
    .check/inspect gas filters: BUT I have not changed it, nor the fuel/water separator since I have not found water on them. Do I really need to change them now?
    also I have not drain the carbs, I had spread them with fogging oil while engine running and do not know if I need to drain them.
    Thanks in advance for the help!!
    I would drain the carbs, if not may have to clean carbs next time run motor. Replacing the filters if up to you.
      Boats.net, Thanks a lot,
      Should I fog carbs again after I drained them? and should I disconnect the gas line on the engine??
