I need help figuring out why the engine shuts down? when i prime the bulb it will get hard. The engine will run great until the fuel in the bowl starts going down. As long as i keep priming the bulb it will stay running. It's like i'm loosing prime or is it a fuel pump problem? It is fuel injected Thanks
1999 Yamaha V Max
Originally posted by rm220 View PostI need help figuring out why the engine shuts down? when i prime the bulb it will get hard. The engine will run great until the fuel in the bowl starts going down. As long as i keep priming the bulb it will stay running. It's like i'm loosing prime or is it a fuel pump problem? It is fuel injected Thanks
Maybe someone can help both of us.
Thank you for the info (just in time) It is a PX150TLRX I see it has two fuel pumps on it. Part #6E5-24410-10-00 #30 on diagram Qty2 is this what i need? they say that the ethenol in the fuel is messing up a bunch of this stuff on the outboards. I just purchased the boat so i will start running the fuel stabilizer. Thanks again.
Yes that is what you need(6E5-24410-10-00), replace both of them.
