Water in cylinder
  • Water in cylinder
    While winterizing my Z200TXRY, and after flushing. I removed spark plugs to spray oil into cylinders. The top cylinder on the left side (#1 head) was loaded with water. Reinstalled plugs and ran engine, seem to run fine. But when I flushed again water returned to cylinder. Head gasket?? Any suggestions?? Engine has never overheated.
    Thanks,
    John
    compression check will show a head gasket leak
