New boat, with 2010 F150. My first 4 stroke. Teleflex Lido analog gauges. I want to add water temp and oil pressure gauges to match (only room for 2 more gauges). Will they be plug and play with the Yamaha wiring harness, or will I have to run wire and new sending units. I'd rather have water pressure gauge, but thats not an electric gauge, need to run water tube back.
Also, the oil pressure gauge is available in 0-80psi, and 0-100psi. What's the normal oil pressure for an F150..
I'm thinking of the command link gauges, but just can't warm up to the digital display, and the need to switch between displays to get the info.
Gary
Gary
