Hi
I am starting to rebuild a Yamaha 200 for my own use. The motor is mistreated by vandals so it is missing most of it's electrics and the top carburetor. And lots of small parts that I will be ordering later.
What US model in boat.net part lists is the same as European 6G6 200 FETO (year code T). If I end up buying a used CDI from my friend can that be off a 225? Or will I need to have other 225 parts also, not just the 225 CDI? Throttle position sensor? The motor is missing the top carb so I don't know about the sensor. What years are the same? Will I add top end power using a 225 CDI and will I degrease it by using a 150 CDI? How is the mapping different?
I am happy to hear if someone is selling used parts of this kind of a motor.
Thanks, JJ
Thanks, JJ
