90hp low compression
  • 90hp low compression
    You guys have been great help. Thanks for all the help. After replacing the head gasket. I did a compression test and got 90's in all 3 cylinder. Is that a bit low? Is there any way to improve the compression?
    forgot to mention the motor does seem a bit weak.
      think the only thing to do would be de-carbon and recheck.
        Maybe run a tank of fuel with Ringfree "decarbon" dosage in it. This might help free up carbon-stuck rings and clean motor/fuel system. Good Luck!
          I will do that this weekend. Thanks
