I checked the fuel pump with a meter for 12 volts with the key on. It functions like it should, jumps to 12 then back down to zero. If the boat starts and runs it stays constant at 12.7-12.8.
The problem is sometimes the pump doesn't run. Is it possible for the pump to be defective and run sometimes and not other times?
