water from discharge port not constant
  • water from discharge port not constant
    I have a Yamaha F40TLRD 4 stroke. water exiting from discharge port is not constant comes out strong and after a while it gets soft for a minute then back strong. Replaced impeller, insert cartridge and o ring. Still the same. Could it be the thermostat?
    Check the thermostat to see if opening and closing properly.
      Water Pressure
      Doesn't the engine have a pressure releif valve? My 90 horse varies from time to time with a new water pump as well. I was thinking the pressure releif valve needed to be changed.
